1 - 2 of 2 Posts
Z06 Power Adder Authority
I ordered my Breathless Vortex stuff from Exit-28 in Dallas.
The Rammer box and Power Duct are constructed well, and the installation instructions were good. Realize this is my first LS1/LS6 to work on, although I consider myself an above average shade-tree mechanic. Nevertheless it was nice to have good instructions which always make the job go smoothly.
I have yet to get the car back to the dyno. I've put ~80 miles on it since I installed the Vortex stuff and it definitely made a noticeable difference. However, I've only had the car for 13 days, and I don't drive it every day...so I'm still getting used to it.
It is very obvious, even if you're a novice at what you're looking at, that the Rammer box is superior to the stock design as far as getting cold air into the motor...and not only colder air, but a larger volume of air than the stock box. With the way the lower air dam on the front end directs air upwards...this thing is very close to being a true "ram air" setup, except there should be no worries of getting water up into the filter. They issue a warning about driving through high water, and anyone who does this deserves what they get, IMHO.
Thanks BPP!!
Glad you like our products and thak you for purchasing them.
Did you get a chane to do any 1/4 runs yet?
Ernie
BreathlessPerformance.com
1 - 2 of 2 Posts
