1 - 16 of 16 Posts
After driving the Z06, I hear water or some other fluid dripping onto the headers, and it makes a horrible niose as the water is vaporized upon contact with the stainless steel headers. I think it's from the air conditioning. Is this normal, or did I miss something when I installed the headers?
Normal :cheers:
Yeah unfortunately the evaporator drains out of a small duckbill on the r/s of the firewall and drips down onto the r/s O2 harness and r/s header. The drain looks tough to get to so I don't even know if replacement with a longer hose is even possible without disassembling the underdash components. I'd rather not have it drip onto the 02 harness but whadderya gonna do?
It's normal, I've had the same thing happen, scared the hell out of me the first couple of time :lol:
Normal. Happens to me too.
I have Kooks and it doesn't happen to me, but my buddy w/ LGMs sizzles nicely. I guess it's the difference in pipe shape. I still get the nice condensation puddle on the garage floor.
I never had that problem with my BPP long tubes either. It must have something to do with the routing of the tubes.
yep my LG's did the same thing, i didnt like it at all so i decided to add a extension tube to the drain valve and routed it to just the right of the right side header, i had to go in from the bottom and it worked, but it is VERY tight to get into and my arms with all the scraches prove it. i think the easiest way to get to it would be removing the r. side header for more clearance if you arms are to big.
1 - 16 of 16 Posts
