I plan on having the rims powedercoated black and covered in real rubber within a week of getting it. Those heavy runflats have got to go. If there's one thing I've learned from this forum is that roational weight is bad bad news.
I'll probably just change the rears for now.
Are there any better tires that will fit the stock back rims?
what is it 325x35x19s?
I'd like something with more grip obviously but also a stiff sidewall so it can handle at 180. Something like the Nitto 555RII's I'm rockin' now.
Also I'm going to want a set of back rims with drag radials. I hear the rims have to be large to cover the rear brakes. Anyone have any clue as to what's needed. Will the ZR1 rims I have no be useless? I assume so.
Nothing like getting a head start on mods. I have no Idea and I don't think anyone does yet. You can be our test Ginnie pig. :lol:
Look at rims that fit the base c6 coupe. The rear brakes are the same on the z06 as the front on the base coupe. So they should fit right?
I know youll want wider, but basically what im sayin is an 18 inch rim WILL fit, and probably even a 17.
