Thanks to all for recommending me to DTE, although I do have a question for all you guys that have cammed your cars. DTE has a new package out now that is supposed to be very reliable as well as putting down some power. I just wanted to know if you think going this route would be a good idea (even price wise) or if I should go down a different road. (I'm looking at doing a cam only swap and am trying for 420rwhp with my current mods) With all of that said, here it is....
1997-2004 LS1 & LS6 Corvette
5.7L Camshaft- Valvetrain Upgrade Package (N/A)
45-55 BHP Gain Over Stock
Performance Package Upgrade Includes:
- Necessary engine disassembly and component inspection
- DTE engineered, proprietary steel hydraulic roller camshaft
- Competition Cams HD dual valve spring set
- Competition Cams HD titanium valve spring retainer set
- Competition Cams HD hardened pushrod set
- Competition Cams hardened steel valve spring cups and shims
- HD Viton valve seals
- HD double roller 3-piece timing set
- New GM harmonic balancer bolt
- 160* engine coolant thermostat
- DTE stainless steel auxiliary AFR sensor bung and plug kit installed
- Necessary engine gaskets
- Mobil 1 synthetic engine oil
- AC/Delco engine oil filter
- DTE ported engine oil pump w/ PRV modification upgrade
- DTE exclusive PCV modification upgrade
- NGK V-Groove spark plug set
- Misc. fluids, chemicals and sealants
- Professional installation and O.E. appearance
- Chassis dyno testing before and after installation
- DTE road/dyno custom PCM calibration
- DTE’s written, limited 2 yr./24,000 mile component/workmanship warranty
Complete Package Price: $3199.00
Thanks!
Eric :z:
DTE has been very reliable, and I recommended them. However, I question a potential 55 bhp increase from just the cam and valvetrain upgrades in the package. Would like to know the cam specs. I think the number would be more in the low 40 bhp range. Does that get you to 420 rwhp? The cost seems reasonable for what you are getting. :thumb:
Bob
Cam installation with crane duals or Comp 921's valve spring kits shouldn't cost 3200 dollars.
I am sure its an excellent package and the warranty is nice too.
A lot of what they have in their description is propriety so its hard to tell all the details...but without the warranty? I know I would pay about 2200 tops. (give or take 10%)
I don't know DTE at all so please don't see this as a flame in anyway.
I'm sure their propietary (sp) efforts and warranty are worth something if you feel you need it.
"A lot of what they have in their description is propriety so its hard to tell all the details"
complete cam package from thunderacing: 500 bucks.
complete cam installation 600-800
computer tunning 450
Total: ~2200 tops
3200 is way too much
I agree, it seems a little high for a cam only package. More than what I paid and I put down 433 whp with a cam only and kooks setup. That was also with the stock pulley and stock t-stat.
