Hi again
what is the normal oil and engine coolant temp supposed to be ...under normal driving.
I got worried tonight, because,
#1, my check light (OBD II) appeared on the dash. Everything seems fine performance wise (and i think the light probably came on cause i had an engine wash 2 days ago, the car was also parked in a semi-humid under ground parking garage)
#2 I noticed as i continued to drive, when i got into some slow moving traffic in the down town area, my oil and engine coolant temp started to rise to about 100 deg Celcius for engine coolant, and about 102 degrees for oil temp.
any thoughts?
(P.S. I also had my oil changed 2 days ago with the engine wash)
thanks for any help
any thoughts?
thanks for any help
