I have a Blown 01 Z06 and would like a fairly aggressive blower cam. I have done some research and can't seem to find one I like. What size cam do you guys use? I would like to know from personal experience so I can stick with one and not have to keep changing it.
My car currently has a weiand intake, LG long tubes, B&B cat back with a P1SC running I assume 5 to 7LBS of boost. Not sure thought since i bought the car this way and do not have a boost gauge yet. I will be upgrading to a D1SC, porting the heads so I can run lower compression and a little more boost :p Andy's kit will also be being used with this soon to be setup. Any info is greatly appreciated.
check out the link in my sig. It has all of my mods including cam size. I told Andy I wanted something that will produce more power than a "nice blower cam" and this is what he suggested.
Jim
cam size
I have P1 with a 224/228 114 lsa cam. Now, I'm changing to D1 but the 224/228 is still a good cam for use with the D1. If I didn't care about expense, I would probably get the 224/230 116 lsa.
I'm with spdrcrj, my cam is very similar, 224/230 @ 114, got it off ebay. There's a guy that sells lots of Comp cams stuff. I like it. :yeadog:
