when you purchase like say kooks headers, what does it bring, does it bring bolts and gaskets too?
I am considering purchasing used headers instead and wanted to know what I need for complete install,
how much would gaskets for it be?
thanx in advance ! luis
You can reuse your stock manifold gaskets, I did when I put the TPiS's on. No leaks.
But yes all that comes in the new box, gaskets, bolts. The TPiS even come with a piece to help with the install into factory cats, if that's what you want to do. I went with Random Tech's though so it went in the trash.
Man!! :cry: I wish I had gotten yours, it would of been sweet, no shipping ect. I guess you live and you learn :mah:
Use only stock GM- LS1 exhaust gaskets, NOT LS6 gaskets.
12558573 gaskets GM LS1 gaskets (#12558573)
Header to head bolts are 2 pass. USE ANTI-SIEZE
First pass is 11 lb. Ft.
Second pass is 18 lb. Ft.
AIR pipe to exhaust manifold 15 lb. Ft.
2) Gm#12553617 air tube gkts.
hpipe to catback gaskets (2x GMPN 10276792)
:z:
Actually mine didn't come with gaskets or bolts. I had to reuse all of the originals. I bought a set of gaskets, but the place that did the installation forgot to use them. I believe they were about $14 each at the dealership.
