My wheel studs need to be replaced from changing wheels so often. What size do I need to get? I would like to go with a set of ARP's, I think they would hold up a little better.
If you have an early 02 with the open lugs, you simply run those without the caps. If you have a late 02, I don't know if the studs are too long for the nuts. I'm pretty sure they are tho, so you'd have to invest in the open lug nuts.
Thanks, I just ordered wheel studs and lug nuts.
