I will randomly get a p0200 (injector circuit fault) code every now and then. I've gotten in twice w/ no ill effects and cleared in both times. This has been about four months apart.
Thanks,
Brian
Super Moderator
Maybe one of the injectors has a bad solenoid. What type of injectors are you running? Didn't you replace them not too long ago? Another thing, check the connectors for dirt, loose fitting, etc.
There have been a couple incidents where the wire insulation was cut where it rubs across a sharp metal bracket at the back of the driver side head.
Have seen several in this exact location..alot of times you wont even see the violation without removing the tape.
Cool I'll look her over. My injectors are stock and the car runs great.
I put a piece of 3/4 in. wiring loom cover on mine and taped it in place no worries mate :thumb:
