I'm about to install a bottle heater and I know it uses quite a few amps. I will be using the auxilary pigtail under the footboard for a switched ignition for the purge solenoid and the switched ignition source of the switches. Does anyone know the maximum amperage the orange 12V constant wire can handle... orange wire being one of the three auxilary wires (yellow, black, and orange). Is there a 12V post anywhere near the battery I can tap into?
