1 - 13 of 13 Posts
Just wondering how much rwhp can be had with the P1 unit...I am at 535 but am sure there are better outputs out there..Wondering how high i can tweek it,,,,,safely :jawdrop: :D
Probably not the highest but my '04 is at 607 RWHP and 512 RWTQ. Stock heads and completely stock exhaust cats and all. Using A&A FMIC kit and running 10 lb. boost.
Later ... Larry S.
I ran out of fuel #'s below
I would suggest staying at 535 unless your willing to upgrade to a forged motor. Im having a forged motor installed next week with the crap below in my sig and Im hoping for 640 rwhp.
I'm going to push mine up to 600 with alky injection. If it blows it blows. Forged 402???? :yeadog:
dbvette....I was looking in your sig. You've had some amazing cars in your time. :thumb:
I have 570 RWHP and a little over 480 RWTQ...All I have engine wise is LG Long tubes, Random high flow cats, Borla Stingers, BBK 80mm TB, Double roller timing chain (good insurance for 200 bucks), and of course a P1 7psi A&A kit with a Kenny Bell boost a pump...No forged motor or anything in that matter...I even have my stock clutch which hold up really well (tires break loose way before the clutch)...However, I always run 101 Trick racing gas. My retard is only 14 up on top and according to Andy (A&A Corvettes) I can get close to 600 RWHP with a little retard (however that is pushing it). In my opinion for street use anything over 600 is a waste on DOTs. Street legal slicks arnt avaliable for my 20" wheels :bmad:
Discussion Starter · #9 ·
Thanks...The Hemi car , at the time, was something that NO BODY wanted ..Sat at the dealer , brand new, they could not give it away...The car never would run right, sold it after 6 months and got a Charger RT...[wife said at least it has a little bigger trunk]wife is now gone, wish i still had the challanger!!! I want to tweak my system a bit more, have the boost come on quicker, and i am thinking the single cooler will help..Also running about 11.8 to 12.0 / 1 air fuel ratio which i think could be leaned a little more...I am thinking i could achieve about 575 rwhp with the upgraded cooler/plumbing/ and a tune... :thumb:
Discussion Starter · #11 ·
lajzo6 said:
All of you guys are making very good numbers, what is the max on a stock bottom end?
My opinion is around 550-575 rwhp, but, it also entails some common sense.....I drive mine hard , but not at 6500 all the time...If someone is beating hard all the time with a 500+ rwhp Z, it will break..My 2 cents :cheers:
The question was 'who has the highest'....
I have seen reported of P1's (with FMIC) pushing 600 rwhp. Is that ideal? Not really. For 600+ rwhp I think you would be better served with a D1 with a larger pulley and a forged motor. JMHO.
Good Luck,
Mark
Discussion Starter · #13 ·
Good Luck,
Mark
The reason i posted this is to find the upper limits of the P1...I plan on tweaking mine to the limit, then, in the future going with D1 and forged internals for 700+ rwhp...
1 - 13 of 13 Posts
