They should....
But each big brake kit is a little different.
Hopefully someone else will chime in with a better answer lol :)
Good luck buddy
G
Depending on your offset...
We used the same Wilwoods, this year, and with out Widebody-compatable CCW Classics 18x13's (rear) had to "massage" the calipers slightly. the Widebody-type 18x12's, up front, fit fine. Again, check your offsets...Talk to Tech at Wilwood and they should be able to guide you. Measure yours, and give them your offset dimensions.
BTW, the Wilwoods do a terrific job!
