No problem, we also carry the column lock bypass.Hossman said:Thanks for the info guys, sounds like a solid mod. RG, thanks for the email too, I will hopefully get an order to you for the weekend.
01ZEE06, thanks for the comprehensive reply too, sounds like the Window Commander is a definite buy. Also, I think the Steering Wheel Lock Disabler is going to be in the same order. Some of the posts I've read sound really ugly when you get stuck.
Thanks all!
Paul
So if you tap the up button once and the window goes all the way up, how do you get it to stop somewhere in between while going up?01ZEE06 said:Also, has a neat feature found in my Lexus. When you're in the car and want to raise the driver's window, just tap the up botton on the door and the window goes up automatically without you having to hold the button down until it stops. This feature only works on the driver's window.
HTH,
Barrie
