MY 2007 ZO6 drivers side window quit opening ( indexing) when I open the door and now have to shut it harder to latch. Window works up and down OK from inside. Have never seen a blue print and don't know What makes it work. and how can I fix it ?
THANKS in advance Steve
This works on my 2008 z06. From owners manual.
After a power reconnect such as battery replacement, the window index-up feature will not function until
the system is initialized.
Once power is restored:
1. Close the door.
2. Raise the window and hold the switch up for three seconds after the window is closed.
3. Release the switch, then hold the switch up again for three seconds and release.
Sent from my iPhone using Tapatalk
Discussion Starter #3
Bruce5793, I just read your reply and went to garage and tried it, and it worked! I sure do thank you for your help. I hope it helps others also.
Thanks Steve
Check electronic cables (pins, cables....) of driver or passenger windows.
For indexing just hold 3 to 5 seconds up the botton window while closing it.
