If you want flawless, you are probably gonna want to start here.....www.gmpartsdirect.com. Here are some part #'s
Early/Mid 2002 to 2004 - Speedline Wheels Z06 Spuncast Wheels
Front: 9594808 & 9594809 - Wheel size: 17x9.5, Wheel Wt. – 19.2 lbs.
Rear: 9594810 & 9594811 - Wheel size: 18x10.5, Wheel Wt. – 21.0 lbs.
Good Luck! :cheers:
As you were, looks like the one you want is GMPart #9594811 Sorry for the mix-up. :bang:
Z06 GM OEM Wheels
Sg Pyle,
You are correct with your first post:
Rear: 9594810 &/or 9594811 - Wheel size: 18x10.5, Wheel Wt. – 21.0 lbs.
The GM Part # 9594810 is on one of the inside spokes of a rear Z06 mid 2002 to 2004 wheel shipped on a Z06 from the factory and the GM part # 9594811 is the one GM Parts Direct has on a Z06 GM OEM wheel.
Dennis
