Ok, question, I'm thinking of putting a Z06 intake manifold on my 00. Question is what all do I need to get to do the job?
Will the oo parts bolt up ok, and any cutting needed?
Thanks for any help in advance
Ernie
Hey Ernie,
The install is really pretty simple. You'll need 3 parts other than the manifold itself to get the job done. They are a new coolant hose for the front of the heads and 2 plugs for the rear. Here are the part numbers:
P/N:12568478 - the front pipe
P/N:12562788 - 2 of these plugs
For a visual perspective and another take on the swap check out Mel's site:
http://www.tradezone.com/vette/
Oh yeah, you might wanna keep an eye on the knock sensor wiring. It's a real tight fit under the '01+ manifold...
What kind of benefits would this modification provide?
I made the swap recently but have been too busy braking driveline parts to get a dyno number so I don't have an exact figure. I do still have an internally stock LS1, though...so the gain is minimal. I'd guesstimate 3-5 Rwhp/tq.
Now a head/cam engine will benifit a lot more. Somewhere in the area of 15-25 Rwhp/tq depending on how radical their combination is.
FYI, here are the results from a head flow test with and without certain intake manifolds. The numbers are in cfm...
Cy. Head In. Man. .200" .300" .350" .400" .450" .500" .550" .600"
Stock LS1 N/A 137 187 207 223 228 237 242 243
Stock LS6 N/A 156 204 225 243 257 268 275 278
Ported LS1* N/A 144 200 225 245 261 272 283 292
Ported LS1**N/A 164 217 234 253 270 284 296 305
Ported LS6 N/A 159 212 236 255 272 300 307 314
With Manifolds:
Stock LS1 LS1 136 184 200 214 222 227 229 235
Stock LS1 LS6 136 186 206 223 227 236 241 242
Stock LS6 LS1 156 199 212 224 232 238 243 247
Stock LS6 LS6 154 204 220 235 247 257 263 265
Ported LS1**LS1 141 185 205 222 232 241 251 258
Ported LS1**Truck 163 206 224 237 249 262 265 270
Ported LS1**LS6 166 211 229 244 257 269 277 283
Ported LS6 LS1 156 199 217 230 242 253 263 268
Ported LS6 LS6 153 202 222 241 257 270 280 289
-originally from "Stage II heads from New Dog, Old Tricks"; GMHTP May/July 2000
-Chris Endres
My opinion is that putting a larger intake on a smaller port usually doesn't provide much improvement because of the turbulence the step causes. Cemo's post substantiates this. Port matching would definitely help. But grinding on installed heads, I don't know.
Cemo, Thanks for the info, i'll take a look at that.. and thanks for the numbers..
Roger,, I have heads and cam on the car. stage 2 heads ported and polished, w/ larger valves.
From what I understand that most tuners after and along with installing heads and cam package they will install the larger intake.
So that was the reason for the question.
Ernie
Roger- I did not notice any difference in fit with the manifold upgrade, ie. there is not port matching problem. The change and benefit of the 01+ manifold to my knowledge is the volume of the extra manifold area. Just like the pre-01 manifold, it's cross-ram design incorporates decreasing runners that increase velocity like a trumpet but the 01+ runners are larger on the manifold side but end up the same size at the heads. This will create a more dense charge...
I was under the assumption that the LS6 intake ports were raised compared to the LS1's...but I didn't find this to be true. Anyone know for sure?
