Does anyone know if i can put a Z06 steering wheel in my WS6? I don't care if i loose the radio controls on the wheel i just want the air bag to work. If it is GM to GM it should work??? Thanks. Mombo.:cool:
Discussion Starter · #2 ·
PLEASE...??? Anyone...??? Mombo.:-?
Hi there,
My only concern is the clearancing at the back of the steering wheel, to the column itself.
The connection for the air bag is the same.
The horn switch will look different, but the end connector should slip in correctly.
I dont think you will have a problem, however, check you clearancing.
You will need a T30, and the special puller legs we use.
Let us know if you need further asssitance, c4c5:eek2:
