.... in case you may want to install one of these kits ....
I selected the A&A kit in part because I put one into my C6 with great results ....but also because I could use the stock hood ...and it was priced right.
The kit is a 10 lb boost system and I also put in a Stage 1 cam and Comp Cams spring kit to deal with the lift requirements of the new cam.
I did all the work myself ..... one of the nice things about the A&A kits is that they are geared toward DIY. The kit has good, clear instructions and literally comes with every part needed. Everything in the kit fit properly and the visible, finished parts look good/proper in the engine bay.
I dont have anything special for a garage set-up or tooling .... so anyone that's handy around cars could do this install.
A&A supplied me with a base tune for the car. Although the car was completely driveable with this tune .... I had it dyno tested and tuned to make sure it was performing as well as it could. In the end, it made 566 RWHP on 91 gas. This gain was about right for a 10 lb boost system ..... which would ideally deliver ~ 70% gain over an engine pumped only at atmospheric pressure (no boost). If I was prepared to run 94 gas .... I think a couple more degrees of advance could have been dialed in for a further 10 or 20 HP gain (?) ..... but I didnt go there.
Aside from a very small lope at idle .... the car remains a great daily-driver. I also had it out to the track recently ..... great performance.
Overall I'd giver this kit an 8 or 9 out of 10 score.
cheers
eboch
cheers
eboch
